Hi everyone!
This may seem redundant given some of these other posts but I'm hopeful I can get some guidance here.
I got a Blaze King Boxer 24 installed yesterday and lit my first fire last night. I noticed a few things during the first burn.
1) The Cat thermometer was pinned far to the right of the active zone for a decent amount of time after I closed the bypass. During this time the Cat was bright orange. Can these stoves take that amount of prolonged heat without damage? I couldn't seem to control the temp with the thermostat.
2) The thermostat dial seems really loose to me and has way too much range in motion. I removed the front plate today to check it out and the knob is connected to the rod that ties into the thermostat. As I turn the dial to the high temp setting (around 6 o'clock) the little butterfly mechanism does open up but the second I let go of the dial, the butterfly closes under the weight of the dial. Further, when I start to move the dial to the lower setting, there seems to be a dead zone where nothing happens (butterfly doesn't move at all) and the dial has no tension on it despite the rod turning with the dial. As I move well past 12 o'clock in a counter-clockwise motion, I begin to get tension again and the butterfly closes. The dial then stops when I get to around 8 o'clock.
I stopped by my local stove supply shop and tried a floor model Boxer 24 to see how the thermostat felt on that and it was solid with little play in the dial between low and high temp. Totally different feel to my stove. Is there a way to adjust the dial travel or am I looking at a dud thermostat in a new unit?
Any help would be appreciated!
