I don't think that makes nearly the difference they claim either.What about soapstone?
Ding, Ding, Ding, - please take it from my experience - I was one of the guys that bought a stove with little knowledge and installed it in my smaller living room with brand new chimney, my thought process at the time was... "so what if it gets warm, I'll just open a window." well... quality of life circled the drain for 2 years then I bit the bullet and took the same stove and re-installed it in the basement so i could watch tv and not sweat to death.That is also why contributors here suggest proper sizing, not just to heat a home, but doing so without the stove room being excessively hot.
Yes, between burning large, thick splits and the cast iron jacket on the T6, we have reduced if not eliminated pulse and glide room temp swings.For you current stove, have you tried to load really large pieces to reduce surface area exposed to combustion? It can really impact burn times.
Yeah, totally makes sense. 30hrs on low during shoulder seasons. I don’t even burn really in the shoulders so I’m not looking for 30hrs. Just a more even 10 or 12.Let me beat someone to this....
You will not get 30 hour burn times this time of year. You can, but your home may not be as warm as you'd like.
Our thermostat is known for the even heat, regardless of which way you go, both companies make great products.
Besides, Soapstone is beautiful!
EPA's NSPS has two definitions for 2020 approved stoves. Those with a catalytic element (catalytic) and those that do not (secondary combustion). I think both qualify for the Federal 25C tax credit.
BKVP
I was actually looking at the T6 earlier based on your previous post. Intriguing stove, but I think it will stick out into the room too far for my application. The F55 has some impressive heat output and could work better for my situation.We get maybe a 2-4º room temperature swing between loadings and a 12 hr burn in milder weather, 8 hrs. when it's cold. In non-cats look at the cast iron jacketed Jotul F55 and the Pacific Energy Alderlea T6.
2-4 degrees temp swing isn’t bad at all. Which stove is that? The T6 you have? How many sq ft?We get maybe a 2-4º room temperature swing between loadings and a 12 hr burn in milder weather, 8 hrs. when it's cold. In non-cats look at the cast iron jacketed Jotul F55 and the Pacific Energy Alderlea T6.
I’ve not until now! We actually don’t like the look of soapstone. But I do like the sounds of the Ideal Steel lined with soapstone. Seems like it might work well for me. Unfortunately the wife hates the appearance even with all the customizability. Apparently that one is out.Have you looked at Woodstock stoves? A Progress Hybrid combines good hybrid cat performance with a traditional soapstone look.
No problem, my wife is of the same mindset. She does not like the look of soapstone and gives a strong thumbs down to the quirky steel stove styling. Their engineering is good. It's too bad they don't collaborate with nearby VC for a nicely styled cast iron jacket.I’ve not until now! We actually don’t like the look of soapstone. But I do like the sounds of the Ideal Steel lined with soapstone. Seems like it might work well for me. Unfortunately the wife hates the appearance even with all the customizability. Apparently that one is out.
They did at one time have OEM work done for them at that facility. It was easier to go with Belgium!No problem, my wife is of the same mindset. She does not like the look of soapstone and gives a strong thumbs down to the quirky steel stove styling. Their engineering is good. It's too bad they don't collaborate with nearby VC for a nicely styled cast iron jacket.
Totally agree. That would be sweet!No problem, my wife is of the same mindset. She does not like the look of soapstone and gives a strong thumbs down to the quirky steel stove styling. Their engineering is good. It's too bad they don't collaborate with nearby VC for a nicely styled cast iron jacket.
Yes, they can, but based on the requirements it doesn't sound like a cat stove is needed. The Lopi Liberty, Osburn 3500, Pacific Energy Summit or Alderlea T6, all fall in the 12 hr. mild weather burn and 8 hrs in cold weather but they have a higher top-end output. In hybrids, the Manchester or GM80, the Regency 3500 are available options.I tend to need 10-12 hrs of medium heat or 8hrs of high heat. It seems the BKs can do this?
