crstrode
I'm on the second season witha BK Sirocco insert - essentially a less adorned twin of the Ashford insert.I just thought I would comment on my own thread and see if I could get additional help rather than setting up a new thread on my poor burn time with my new Blaze King Ashford Insert.
I had this vision of loading my wood stove and, walking away and so far my experience has been the opposite. Im trying to rule out issues that may be the culprit, and this may still just be human error and burning subpar small firewood, but if I could just get a 10 hr burn, I would be ecstatic! My longest burn time was 6-7 hrs. (down to coals) I have tried stuffing it with a lot of wood, (Its a mix of Ash, Cherry, Cedar and Hickory I believe) I dropped $7k last spring on this unit with installation, and I want to better understand why its not performing to my expectations. I want to rule out the firewood variable first. How do you do this? Can i just load it up with kiln dried 2x4s? I don't want to overfire!
Previously stated that MC was anywhere between 9-15% but those pieces were on the small size. I have moved on to 18"-22" pieces, and found some MC around 20%-22%. (Don't know how big a deal that is, but I usually set them aside, only burn under 20%) Because you can really only fit 2-3 of these bigger splits E-W, I've taken some large pieces and cut them on the chop saw so I could insert them N-S. Even, when I think Im loading it up to the gills, it seems like in an hour everything has settled down and there's a lot of space left.
There are couple of things I am noticing, that I just want to list here. Maybe someone can help me dial it in.
I know I am not going to see the same benchmarks as a freestanding stove, and a lot of other factors might play into this (home insulation being one) Im feeling frustrated and want to better understand if there is an installation issue or if this is just subpar wood that isn't allowing me to get the avg burn time. I've burned about a 1/2 cord since Nov and at this rate, I will probably run out of wood by February.
- I notice that within a couple hours of starting the stove, the CAT thermometer drops significantly, and eventually almost out of the red and this has me increasing the airflow slightly to keep it in the red. Does this indicate too strong of a draft? or subpar Firewood? I was hoping it would stay in the active range for the whole burn time.
- I can't seem to close the air off completely - every time I do this, it seems the CAT stalls. My process so far has been - Once I have the fire going, latch the door and wait for CAT to be in active range. As soon as its in the RED, closing the bypass and I have been waiting about 10 min so that all the pieces catch (or most) and then I dial down to the half position and then another 10 min further to about 12/1 o'clock, On cold day, the house doesn't seem to get past 66 on a mild day the house is 70. Id like it to be 70 every day all day
- Should I be using the Blower? It seems every time I use it, while it helps to push out heat into the room, it seems like it has a direct effect on the CAT and causes it to drop in temp. During a mild temperature day, I left the blower off and the stove seemed to perform better, heating the downstairs to 72. I have since not been able to replicate this. Im guessing outside temp is the reason.
I appreciate any guidance or help, I have added some details to my signature if it helps. Cheers!
I'm guessing that your wood may be a little high in moisture content, and you may be expecting too much in terms of how big a house this appliance can heat. I posted some opinions on my results here:
Trouble with Blaze King
It is an interior chimney, in the center of my house (L-shaped bungalow, 1500sqft, built in 1974). I don't believe there was any block of plate installed, just a liner. Would you recommend a block plate? Absolutely a block off plate will increase the heat being delivered to the house quite a...
