I'm just starting season 2 on my Blaze King Ultra. First season I had a few struggles getting used to the nature of running with a cat - see forum link. Once I worked it out, it runs good but not great. By this, I mean it's not performing as well as I expected.
I can run it hot under full-throttle, but it's not as hot as my previous quadrafire and chews through the wood just as much. I can run it low to get longer burn times but then the heat output isn't really much and the run times are not that exceptional (~8hr) - again not much better than my quadrafire. The details are in the other thread, but I have a very long 8" flue (~25') and am burning lodgepole pine at 15-20% moisture.
I'm starting to wonder about my air control and am hoping someone can tell me if it's normal or worth exploring.
If I rotate the dial high to low, the air flapper 'clicks' closed at the 3'oclock position. This is regardless of hot or cold stove. So this means, I only have from 3'oclock to 6'oclock to work with for air control (what's the point of the other 75% of the dial?). At 3'oclock, my stove usually doesn't have enough to keep the cat from stalling out. I normally have to run the stove at ~4-4:30 to keep an active cat that produces enough heat to be viable and get through most of the night. At 6:00, it's active flame and high heat, but as I mentioned I kind of expected higher heat.
Also, my understanding with the air control is that it would adjust to keep the stove at the temperature you set. This doesn't seem to happen. I set it at ~4:30 and it initially produces good heat with a full load. As the load burns, the stove gets progressively colder. Not drastically... it slowly cools through the night though to borderline stalled out in the morning.
