Lousyweather said:
Actually, the feed rate DOES matter, but not how you think it does. Think of the feed rate as setting the MAXIMUM feed, in a worst-case scenario. The circuitboard and probes actually control how much pellet actually feed, but you can think of the max setting as a timing in a worst case situation. Lets say the stove was installed out in the front lawn, in sub-zero conditions, and set on Room temp mode. if you set the stove on a feed of 2, then the stove would run for about 20 secs per minute......if you set it on 6, the max setting, it would run without stopping. In a room, the stove usually satisfies the thermostat long before that max setting is reached, so it isnt a big issue, unless hte feed is set far too low, in the misguided attempt to minimize pellet consumption.
you put that stove outside in room temp mode and it won't care what feedrate you put on it..it will keep feeding itself till it reaches the desired temp..if that probe never reaches the desired temp it will run full bore till it runs out of pellets....
now if by some miracle it heats up the ouside to the desired temp then it will gradually feed itself less and less pellets irregardless of what feedrate you set it at..afterwards it will just give itself enough pellets to maintain that temp it reached.....
Harman designed this stove to be very easy to use by just setting the temp you want and letting the stove determine what IT THINKS is the best feedrate to give itself..it readjusts the distribution/combustion fan speeds automatically...its a very smart stove
..it could give itself a few pellets to keep it steady at the desired temp or give itself alot of pellets if its starting up OR if someone decided to put it out in say sub-zero weather..OR stick its probe out a window...
that rule about feedrate at 2 =20 secs is hogwash IMO...
i've ran feedrate 6 with temp 4(
Stove Temp Mode)and ran
Room Temp Mode 70 degrees with feedrate 6 and guess what???
..it didn't run for 60 secs. in either case...
Room Temp Mode it ran for 22secs and ran less and less as temp reached 70(..afterwards it just fed for 5-10 secs then off for 50-55secs. till it was needed again but only in in manual igniter mode) or it turns off completely in auto igniter mode till the temp drops and then it reignites(btw thats alot of wear and tear on the poor little igniter,just set it in auto to start and flip switch after to manual so it idles and doesn't die out)..
Stove Temp Mode it turned for only 3-5 secs when stove reached set temp...but fed itself the max pellets allowed while it fed for those 3 secs...all while on feedrate 6
now I REALLY don't want to get people pissed off at me but Harman designed a great stove with real crappy instruction on what those numbers are suppose to be for...all we have is heresay(like mine)...
SO HARMAN..MAKES US A DAMN CHART SO WE KNOW SOMEWHAT WHAT THESE SETTING WILL RESULT IN..PLZ
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
(yes I know not all pellets are the same)BUT GIMME A ROUNDABOUT FIGURE ....
Let the negative comments commence.........
