That depends on how cold it is outside. If it's warm outside then the cat is eating a lot of smoke and there is not much visible flame, btu output is low. If it is cold outside then the stove is being fed more air so less smoke is generated and there is more visible flame and btu output is higher.If a Cat burner is "smoldering" is it giving out enough heat to 'heat'?
No, you control the heat output, just like with the Lange. If the outdoor temps are mild you are not going to be loading the stove to the gills and running it at a high temp. Less wood + less air = less heatIf a secondary burner is at 1100°, is it warm, hot, or very hot?
![[Hearth.com] BK vs Secondary Combustion Stoves? [Hearth.com] BK vs Secondary Combustion Stoves?](https://www.hearth.com/talk/data/attachments/199/199982-d5e60c16fbf82984a608f74a9f8c39f0.jpg?hash=ePCsfa24ZV)
![[Hearth.com] BK vs Secondary Combustion Stoves? [Hearth.com] BK vs Secondary Combustion Stoves?](https://www.hearth.com/talk/data/attachments/199/199990-f3e89e42e9b59a4a67d3e383a7a2cee6.jpg?hash=wXCS_XpeGj)
