I am narrowing my choice for a new stove (or maybe an insert). Blaze King sounds too good to be true, but I am trying to make sense of it. I hope someone can help me with my confusion regarding flue gassed cooling and the making of creosote.
Blaze King has printed in their literature the following:
"Burn 33% less wood. The combination of our exclusive thermostat and catalytic combustor technology makes your Blaze King insert one of the most efficient wood inserts in the world. The proof of this is in our flue temperatures. Non Blaze King inserts have flue temperatures of between 600° F and 900° F while your Blaze King flue temperatures are between 200° F and 300° F. Non Blaze King inserts pump valuable heat up the flue while your Blaze King keeps the heat in your home saving you money. Our highly efficient inserts will burn up to 33% less wood. So you cut, stack, load and clean 33% less wood."
Don't those higher flue temps keep the creosote to a minimum? If Blaze King has cooler flue temps, why aren't the liners full of creosote?
A salesman told me today (he sells a lot of brands including BK), 'the only difference between a secondary combustion stove and a BK are the BK's long running times. If you want a 30 hr burn - it's BK. If you don't mind stoking the fire every 8 - 10 hrs, it's a secondary combustible stove. That's the only difference.'
Help?
Help?
![[Hearth.com] BK vs Secondary Combustion Stoves? [Hearth.com] BK vs Secondary Combustion Stoves?](https://www.hearth.com/talk/data/attachments/199/199973-07fef45092236c5da311a0e753dd5413.jpg?hash=mBVV6TTKAZ)
![[Hearth.com] BK vs Secondary Combustion Stoves? [Hearth.com] BK vs Secondary Combustion Stoves?](https://www.hearth.com/talk/data/attachments/199/199980-2143bc5ab924a8be362456a0163120b9.jpg?hash=psHuj957zp)
![[Hearth.com] BK vs Secondary Combustion Stoves? [Hearth.com] BK vs Secondary Combustion Stoves?](https://www.hearth.com/talk/data/attachments/199/199981-f96cfdc42737ba8ab0f836c027dc1e29.jpg?hash=Ki1k2SinF0)
