- Dec 13, 2012
- 74
Last night I was able to get some help getting the stove downstairs and installed. This thing is huge and was a bear to get into my basement... For now I'm running the king on a 6" class a chimney that is 18' tall. I have a single wall 8" T inserted into the stove for easy sweeping and cleaning. After the T, I neck down to 6" single wall for roughly 3 feet until the class a.
The door latch is new and improved over the previous design. The wedge on the door handle is a better design and the adjustable bolt on the stove is machined flat to reduce wear on the wedge.
I removed the thermostat cover to check things out because the friction holding the knob at a specific setting was so light that at certain settings the weight of the butterfly valve will rotate the assembly closed. I couldn't find any adjustments for this so I'll have to figure something out. While in there I noticed the butterfly valve doesn't have a hole in it like my princess did.
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120216-a643460e949b2dc201e58f9009bcebd5.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120207-7ebb757e62d47a1d83f365fa5920875e.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120208-4995cb1b8e27612e6be07150cf89a60f.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120209-6c3d0cc7c5241873d292739151bbc076.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120210-12b323bf4949805d044ef278100a87ec.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120211-df71dd24bfebf75d5560e4e79a0898a7.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120212-eccdc6d7301352432c9c45c903bf4d16.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120213-78a67fb62ea2f8723a416009a8a688ce.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120214-096cf822e594c39368eb58249880a3a6.jpg)
![BK King Install BK King Install](https://www.hearth.com/talk/data/attachments/120/120215-4a902e22be3e171c793c7ed3efc31fbe.jpg)
