Yes I burned 5 bags so far going back to stock up! The ones I got were real light in color I think they ere softies.my stove loves them! Not much ash and the heat is pretty good,not a bad buy at 4.50 a bagHave you burned em yet? Any good?
What did you pay for your Okanagan's? I have only been able to find them around $400/ton in MA unless I am looking in the wrong placesI'm wondering the same thing. How have yours been? My local TSC has the soft wood ones for $5.29/bag which is $265 a ton. Cheaper than the Okanagan Platinums I'm burning now. My stove likes soft wood pellets over hard wood pellets or blends. I'm tempted to buy em. Which ones did you pick up?
I paid $330 a ton picked up from a dealer in Colchester CT. Probably too far of a ride for you unless you can get multiple tons in one shot.
yikes... I tried 10 bags of green supremes and felt the same way .. first time I had to scrape cabon off of the burnpot as well as out of the end of the auger chute above the pot, switched to some Heatr's I bought at HD and they were far better, still some in the hopper, the Big Heats are next for a trial run if the temp drops tonight and I clear the Heat'rs out of the hopper. The BH's are lighter in color than the Heat'rs and much lighter than the GS or the NEWPs I have.. we will see.. 10 bags and even if they are not great they are worth a tryThe last time I tried Big Heats my stove needed an enema![]()
I too have the Lopi AGP insert recently installed. I noticed since burning the Heat'rs that I recently purchased that it creates black soot on the top of the insert. It eventually burns away. but just wondered why. Do you see the same in your insert? Is this normal?
I see that when I fail to run the stove for an hour or so on a higher heat setting.. it seems to happen with most of the pellets I use... I'm guessing from your location you got your insert at the same place I did.. I need to stop in and get some more touch up paint and some guidance on a complete pull out and tear down for a thourough cleaning
