better sharpener?
I skimmed the posts...
What angle do you guys prefer...since you can set them on these little grinders?
The angle will be listed on the box for the chain. 30° is probably the most common for Stihl, 25° is common for Oregon. This image is from an Oregon chain box.
[Hearth.com] better sharpener?
Quality chains have a mark on top of the teeth they want you to paralell. Some refer to this as a warning mark to replace your chain.
I have both the 2 in1 and a close cousin to the HF unit mentioned above. The HF unit gets put into service if I have a damaged chain or need to true the angle of the teeth (after many sharpenings I can find variances in the teeth angle. My fault I am sure, but the HF unit corrects that quite easily). The 2 in 1 is used for all other “regular” sharpening as I feel the curved tooth that a file produces is superior to the flat face that the grinder produces. And no guessing on the raker height with the 2 in 1. It does the measurement for you.
Reactions: Soundchasm
