+1Did anyone catch that he has already heated with a Dutchwest 2479? All stove mentioned exceed this stove's btu output by a considerable margin.
The basement is finished completely. The wall as are all insulated. The reason for burning wood is there is no gas available at my house. The house is heated with electric baseboard heaters.
I would like a stove that is nice to look at. It is more or less what you see when you enter the house where most people do. We do not sit in front of it often. The room down there with the stove is usually too hot to stay in long. Let me know what other info you might need to help with the install.Mike
Nimrod, that's what I was worried about with the soapstone stove. I was thinking in my head "soft heat" is that going to work for me? I am worried it won't make it upstairs. My uncle and grandparents both have hearthstone Mansfield stoves and love them, but they both have them on the main living room level where they watch tv.
Oldspark, I do have 8" chimney. I was interested in that stove just stickers shock on that unit.
I can't help but worry about the englander nc30. I usually don't buy things at big box stores so it makes me worried about the low price. Not that low price equals low quality, just makes one wonder.
The wood was all cut last year and most all split this spring. The stuff that wasn't split this spring I stocked first so it will sit longer before being burned.When was the wood split and stacked? If the wood is well seasoned you could be burning less.
There is about 25% oak in there. Mostly all maple.If there is oak or hickory in the mix it might be better to set it aside for next season.
Ok I think I may invest in a moisture meter then. Might be nice to have while being a newbie at this to make sure my wood is properThe wisdom here is that oak needs a couple years to season well. Out here the same is true for madrona. Burn it in one year and it will be ok, but wait for 2 years and it is awesome. If you take a moisture meter and resplit some of the oak splits then test the freshly split face for moisture content it should read at 20% or less.
Thank you everyone for the suggestions. I'm going to re-read everything to make sure I didn't miss anything.
Does anyone have the PH and burn 24/7? I'm just wondering the range of how many cord of wood anyone is burning that stove and others?
Thanks again guys
Exactly. I'm not trying to discourage a King, but a Princess, Summit, Liberty etc. would all match or exceed the old Dutchwest's performance.The 2479 is a 2.8 cu ft stove. About the same size as the Princess or the Progress. The liberty isn't much larger at 3.1 cu ft.
Hey guys,
I'm new to the forums. I bought a house in the country and it came with a dutchwest 2479 non cat stove in the basement. A Few of the cement pieces inside are cracked and I got prices to replace them and will now be getting a new stove based on those costs.
My home is a raised ranch 1100sq ft on the first floor (basement) and 1400 on the second (main living) levels. The woodstove is located at the far end on the home under the living room and kitchen. The main stairwell is located in the center of the home with the door open to let heat rise. There are holes cut in the floor to let the heat come up from the basement.
My question is what type and size stove would heat my home the best? The stove I have now does an ok job and I like being able to burn larger logs in the large box.
Currently I was thinking:
Woodstock progress hybrid
Hearthstone Mansfield
The big thing is I don't know if the gentle heat of the soap stone is best for my situation. looking for any input.
Thanks in advance. And what an awesome forum you have here!
Mike
