bbc557ci said:Something I just thought of, I'd like to figure out a way to force feed some heat into the basement. The laundry and a small work shop are down there. There's a closet wall about 3 feet from where I plan to locate the stove. I'm thinking a cold air return grill near the top of the wall, and then box in a fan/blower to pull some warm air into the basement. There's another wall in the living room that would accept a similar arrangement. Sucking heat into the basement would rob a bit of warm air from the living area. Given that, the Mansfield may not be much overkill after all.
I'll be stopping in at a few more stove shops this week to see what's available, and what my options are. I'll mention also, I'd like to go with a non cat stove. Just for ease of operation and simplicity. If I'm not around my wife may need to fuel the stove. The simpler the better, trust me.
It's late.... maybe I'm becomming delerious....
Thanks again for all the input and advice.
As an additional note, I would agree that I don't think we've had any really successful methods of getting stove heat to go down into a basement. I would also add that Codes don't allow cold air returns to be located w/in 10 feet of a woodstove that hasn't been rated and designed for it.
I think most folks that need intermittent supplemental heat in a basement end up with some sort of auxillary heating system, either a small electric space heater, or using the furnace as needed.
Gooserider
