Hi, I'm new to the site. I'll start off by wishing everyone a Merry Christmas!!
I've spent the last few hours reading through posts on this forum and can tell there are allot of well informed people here. This is a great place!
That said, I could sure use some advice. I live in central NY State and presently heat our house with LP gas. The cost to heat with LP is well, crazy to say the least. So, I've decided to put a wood stove in and use it as the primary heat source. In reading many of the posts here, I've come to realize that much of the information included in manufacturers brochers can be less than adequate, when deciding on the right size and type of stove.
Regarding the size of the stove, I've read in several posts that using the size of the fire box in the stove is a good way to choose a stove. Possibly better than using the manufacturers BTU ratings, or their max square foot heating capacity.
I'll describe our house as clearly as I can. The house is a "salt box" design with full basement. I plan to locate the stove on the main/1st floor in the living room. The 1st floor contains +,-900 SF. About 1/2 of that is a living room with a vaulted ceiling. The ceiling is 8 FT at the short side, and 17 FT at the high side. The kitchen and dining room are in the other half of the 1st floor. Both have large arch ways separating them from the living room. Upstairs is about 400 SF and there are two bedrooms. Doors to the bedrooms are open and or visible from the living room. All in all, the house has a relatively open design. So I think heat from a stove located in the living room would reach all areas/rooms pretty well.
The house is about 20 years old. Insulation, windows, and doors are "adequate" but certainly not air tight. The windows and doors leak a little when the wind blows, but not real bad. The house is located at a relatively high elevation and is not protected much from wind by trees, other houses. In other words, we live in the sticks
I plan to locate the stove in the living room next to a gable wall, and run insulated chimney material straight up from the stove, through the ceiling/roof. There will be about 10-11 feet of chimney inside, and about another 10 feet of chimney above roof level, to conform to code.
Total SF of living area (not including the basement) is about 1400 SF. With the vaulted ceiling, my guess is it would be comparable to heating a 1600 SF house ..... a guestimate on my part. I need to take into consideration the cold central NY winters and wind when choosing the right stove. Mixed hardwood is readily available in our area.
I like both the Jotel cast iron, and the Hearthstone soap stone stoves. Both are available locally and they both seem to have great reputations for quality. And they are both good looking units. But man, I sure could use some advise on what size stove to get :question:
Any help would be greatly appreciated !!
Oh.... sorry for such a long post .......
Thanks -
Thanks -
