Well folks,
I got the holes cut to put in my Selkirk DT wall thimble. The interior went pretty well. Lining up the exterior hole and cutting the corrugated metal siding was another story, way harder than I figured it would be.
Now, how should I trim it out? It needs something in between the exterior wall and thimble plate but what to use because of the wall’s ridges? They make foam like corrugated sealing stuff. I was thinking of 1” boards with that shaped foam underneath?
I still have to put silicone around the edges of the pipe. Then I thought I would put the wood trim up and silicone around that edge with the shaped foam under the 1”boards.
Maybe that exterior wall thimble flange should be underneath the siding and use J-Channel? But that’s not going to happen by my hand anyway. I would have to take gutters and all kinds of trim off to do that. I would have to hire it out if that’s what it needs.
I have not yet put high temp sealant on the edges of the pipe at the connecting points per the Selkirk instructions. Is that absolutely required? The dealer told me if I did the pipe edge sealant, I would have a hard time if I ever needed to take apart the pipe for cleaning.
I was about 1 1/2 hours getting the pipe all connected to see if it all lined up.
Also have not put sealant on the Selkirk 3” to 4” adapter that connects to the stove’s cast iron exhaust outlet.
![Best way to finish exterior trim termination thimble? Best way to finish exterior trim termination thimble?](https://www.hearth.com/talk/data/attachments/291/291285-a3ab0370d5724aeeab981a0c26ad2a1d.jpg)
![Best way to finish exterior trim termination thimble? Best way to finish exterior trim termination thimble?](https://www.hearth.com/talk/data/attachments/291/291284-c827321e9e4ef451dc66141a3ad4f656.jpg)
