Best way to buck large logs?
Backwoods Savage said:
Most hardware stores either have them or can order one. You can do a search for cant hook also. You want a cant hook rather than a peavey. One with a 3' or 4' handle should do everything you need done. Mine is a 4' handle.
I disagree. Everyone who cuts their own firewood should have a peavy.
The handle on my peavy isn't much longer than 4'.
We are talking about the same thing, right?
Seriously, I have never seen one new.
I must pursue this as I need one badly.
cheers
I can't imagine every saw shop in BC not having one
lobsta1 said:
I've got a peavey & I think it is useless. I can't get a bite with it on the big stuff & I don't need it for the small stuff. As far as cutting big logs, WEDGES are your friend. I am cutting up 4' diameter oak right now with a 6401 with a 20" bar. I have to cut it into chunks. I start at say at 10 on the clock & go over the top with the entire bar buried & then down to bottom bark on one side. Then down to the bottom on the other side. Then I rip down the face in thirds as close to the bottom as I can get. Then drive some wedges down & split the chunk off the bark. Then crosscut horizontally across the face at the depth I was able to hit coming down from the top. Leave the bottom center until I get the next section cut with the outer two third sections cut off. I can now come back for the bottom center section. Only thing is even though I am only cutting 14" cookies, I still have to rip them down to smaller chunks. They are just way to heavy to move otherwise. Oh yeah, I also can't use my pulp hooks for the chunks. They just bounce off!
Al
Kinda odd
There are two possibilities here
1) You have a piece-of-sh_t peavy
2) Operator error
Perhaps I should have worded that different. My fault. Around here it is easy to get one.
However, I still say you should use a cant hook rather than a peavey. Perhaps some think they are the same thing and they are not. They are similar but not the same.
Once you start using a cant hook, you will probably wonder how you ever got along without one! Unless, of course, everything you cut is really small stuff. Then you need a sawbuck.
Is a cant hook a peavy-like device with a cleat on it that lifts the end of a log off the ground? If so we call them log-jacks. They're handy if you're cutting with a partner and the logs aren't too big - the ones I've seen/used are not stout enough to roll the big fir.
No, not the same thing at all. Check out the link and scroll down just a bit for a picture which shows them side by side.
Cant hook vs Peavey
If I was cutting large log lengths in the yard , I'd build up the ground with a little crown.
Dirt, shavings, mulch whatever.
A few wedges to help hold things on the crown.
In the woods I use branches and roll onto them.
A cant hook or even just a branch as a lever works.
I've even levered fence posts/rails on bigger stuff. (including to get a stuck bar out)
The bigger stuff does test your engineering skills a little bit.
Best way to buck large logs? guess what a peavy cant hook or timber jack is not going to work on large trunk. I wouldn't worry about the chain hitting the ground just do your best and keep cutting til it is manageable.Peavy's are great tools but the saw is the weapon of choice on a big trunk.
I strongly recommend the Logrite peaveys and cant hooks. I paid about $125 for my 4' cant hook with the timber jack attachment--I absolutely love it! It's not cheap, but I could probably use it lift the rear end of my Tacoma out of a mud hole if I had to......it will definitely outlast me!!
NP
NP
I'll agree with this. I bought a Logrite peavey with a timber jack attachment and love it also. Yes, not cheap. So? Neither was my saw.
Spikem said:
NP
Looked at the LogRite site. Didn't find a peavey with a log jack on it.
Big Redd you might be thinking of a 'tree jack' here's what spikem is talking about ....
(broken link removed to http://cgi.ebay.com/LOG-WOOD-TIMBERJACK-LOGGING-TOOLS-CHAIN-SAW-ASSIST_W0QQitemZ230411371311QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a596832f)
That is what I'm thinking of. What is a "timber jack"?
