Hi all,
Well, I'm learning a lot and have begun feeling a decent mastery of the stove now. I'm going to write a review at the end of the season with more copious notes, but I thought I'd share two things I've learned so far:
1. A Lopi Republic 1750 can heat a 2-story 2000 square foot colonial using semi-seasoned wood and cruising at 400-550 degrees, even when it's placed in an exterior chimney on a wall far removed from an ideal location. The home has been reading 68 degrees in the cooler parts when its 30 degrees outside and the stove has been running for 6-8 hours straight.
2. (the real recent learning) Lopi has a damper bypass lever that allows exhaust gases to shoot right up the chimney. This allows for a strong draft to be formed and helps reduce smoke puffs into the room during loading a hot stove. I had been leaving this open for the first 15-20 minutes of the fire forming until the fire was nice and strong and then i'd shut it either all the way or 50% and then all the way once the fire got up to 300-350 degrees.
No more. As soon as the fire is caught (i.e. firebox is not filled with smoke so the draft is formed, and it's not just newspaper being lit), I close that damper bypass and let the smoke curl around and up. The door is left open a crack during this phase and for probably 10-15 more minutes.
Since doing that, I'm getting far healthier and hotter fires far sooner. It seems to have no ill effect on draft and I'm typically using 450 stove top temp within 15 minutes now.
It's great!
Joe
It's great!
Joe
