I am seeking recommendations for single-wall stovepipe.
I installed my BK Princess last winter with some old pipe
(from my old stove), as an experiment. I found that the
stove did just fine with single-wall pipe, despite BK's
rec to use double-wall (which they freely admit is a
distinct possibility if your chimney has good draft). So
I want to do a better/prettier permanent installation now.
Additionally, since most single-wall pipe only comes in 2 or
4ft lengths, I only had 2ft coming up from the stove before
the dual-45 offset (to the dripless smoke-pipe adapter from
the chimney). So I'd like a line of single-wall pipe for which
3ft sections are available, so I can at least follow THAT part
of the rec ...
Thanks.
of the rec ...
Thanks.
