bogieb
My vote would be for up and out. Get a better draft that way (usually), which means less chance of smoke in the house in the event of power failure.
I'll have to look into the proper ways to vent the harman xxv. I do like the looks of the up and out but just more money and I like the idea of radiant heat
I personally believe that up and out helps keep some of the heat from just going out with the gasses that are expelled - it warms up the pipe that is running up, and radiates it back into the room. Is it a ton of heat? No, probably not, but you still recover some of it.
That is a good point - I was going with my experience using Duravent with a separate OAK.If you use the Selkirk DT, you won't have any radiant heat from it. The cold air is brought in through the exterior pipe that surrounds the interior pipe (exhaust). This is how it preheats the air for combustion. The longer the pipe run, the more you can preheat the combustion air.
Same here, went with the top vent option through the roof (log home) but that eliminates the integrated vent and Oak from Selkirk. Top vent option will run you $300-$450 depending on your dealers mark up.well I wanted a P series but my wife loved the looks of the xxv. She won this time![]()
