Is it on an exterior wall of the house?It is approximately 10 feet tall inside and 3 feet outside. All brick with nothing in it.
That chimney isn't very tall, so i would do everything you could to increase the draft.
I just got on the roof and measured down the chimney and it is 11 feet. Now I am getting worried because I already ordered and paid for it.
im pretty sure your gonna need at least a 15ft minimum chimney, I think all the new EPA stoves require that. I think I have only seen one stove that I have looked at that was an EPA stove that specked a chimney less than 15, at like 13 or 14.
What else I found was pipes to a fan that circulates air around the back of the fireplace. There is no way to get a pipe through them so I imagine I will have to cut these out?????
how is the fire place being bigger, give you another 3-4ft of height on your chimney? Or are you talking about area to put the insert in?Okay, I just took out the fisher that was slammed in there and found the fire place is a lot bigger than I suspected. It will add about 3 to 4 feet so I should be good. What else I found was pipes to a fan that circulates air around the back of the fireplace. There is no way to get a pipe through them so I imagine I will have to cut these out?????
