What an odd setup for a fireplace. Granted I don't see many installs but I have not seen a fireplace with just a terracotta liner piped to it all the way on the right. I question how well that would work for a fire in the fireplace.
Flex liner "flexes" but only so much, depending on the height of the insert and a couple other variables you might be able to use an elbow like I posted above and "flex" the liner to the connector. This would be the best way and should not hurt your draft as much as using an offset box or 2 90 degree elbows.
Hot water heater or furnace?
Not really sure, this was a custom job with the way they did that fireplace flue so it might just be a backup of some sort for later expansion.
Is there really any reason not to go with the BK Princess as long as it fits??
To get your wife to accept its look? If she is ok with that it would be a good choice for you.
Btw. It looks like the flues are all the same height and pretty close. You may need to either plug the flue from the upstairs fireplace or extend the flue of the insert. Otherwise, you risk smoke downdrafting back into the home through the unused flue.
In this case the Princess insert would be a better choice. One thing to think about with a freestanding Princess is the thermostat. It may not respond correctly by being in the back of the fireplace opening. It could also be hard to see and adjust.Man, keep reading so many good things about the BK Princess, I decided to take a little closer look at measurements and fit...
Checked clearance for sides, depth and height. It would actually tuck into the fireplace really nice and snug.
Opening is 34.5 wide, BK is 27", plus it calls for an extra 2.5" on each side - good there. BK calls for 9" on the back side (with fan option) - good there. Will need to add some tile for combustion, but no big deal. And, good in height - our opening is 34".
I think I can move the pool table over enough to make it work.
I'm not too concerned about the flue being off to the right. Doesn't look like that angle would be any worse than those that "angle back".
I really like the ability to run the BK P fairly low and still get good burn times.
Is there really any reason not to go with the BK Princess as long as it fits?? And, I'm talking stove, not insert.
$5500 installed with hearth extension and 22' insulated linerPlan is start with the wood insert in the basement. Hoping to at least have some impact on the propane. How much is unknown. So we'll just have to see. I plan on doing what I can to increase air flow throughout the house as well. I can see us spending more and more time in the basement, so it will def be worth it. The plan is to most likely add a pellet stove or insert eventually on the main level to help balance it out.
We have the same kind of carpet/concrete setup - so thanks for that info. We are looking to replace the carpet really soon, so I'll take that into consideration when it comes to the carpet and pad.
Do mind if I ask what you paid for the Clydesdale?
Thanks!
