Dairyman
HOWS ABOUT THIS---Makita 6401 upgrade to 84cc?![]()
That's a good option.
I always wondered what the diff was between the 066 and the 066 Magnum. Seems to be the same saw, on paper.I swear, I get just as much chips from that 66 mag as I do stump grinding! The 66 mag, is absolutely the best saw.
Uh... just by chance, does he sell saws?Well in the meantime...just picked up this lil fellow from the shop!
No scored nothing, burnt cylinder NOT! (I don't know what type of hallucinogens my previous saw tech was on!)
He swore up & down the saw was toast!
Carb work/fuel line...$60 and "DA DA!"
THE 116SI IS BACK---ONE PULL---ONE START![]()
GLORY
View attachment 172904 View attachment 172905
Just started using him...he may have a few "left after 30 days" type deals...no retail/dealer type saws though.Uh... just by chance, does he sell saws?
Agreed. I have the 064 AV and 036 Pro. I have to remind myself to put hours on the 036, sometimes. The 064 rips, and isn't all that heavy.A used 064 in good shape would be real tough to beat. I like the 372 xp also but its definitely down a few steps from the 064. Since getting my 064 I haven't even picked up my ms 360 pro.
Well fellers, my accolades & hoopla were all premature...just filled up the 116si started on one pull...cutting through elm & black locust like butter for about 5-6 minutes...then all of a sudden she cuts off like someone hit a switch!
Cannot get it to restart...and now the pull cord sounds like it's made out chain and pulls out like thread off a spool
No resistance in the cord at all, everything is sounding very metallic...feeling no compression!.
ANY THOUGHTS...that are not ominous?
@ Wits End.com
I'm a novice at this...so bear with me.That top edge is odd for sure, but it doesn't look scored.
Those are your piston rings, hardened c'rings of chromoly steel, and they look good. Scoring would be vertical lines in your photo. The horizontal lines are normal machining marks. Run the piston up and down, and look for vertical lines.I'm a novice at this...so bear with me.
Those dark rings, what are they and what exactly would scoring look like?
The 064 should be down a few steps over a husky 372xp. Isn't the 064 a mid 80cc platform ? The 372xp is a 70cc saw.
May want to check spark plug. My stihl 441 quit all of a sudden like yours did and it turns out that the spark plug came out.I'm a novice at this...so bear with me.
This doesn't make any sense. You're right that the 372 is smaller than an 064, but that's exactly what Jazzberry was saying.
