Jimxt88 said:
I'm afraid you have lost her. You guys went right over what her primary concerns were after keeping her house heated..." but I’m a middle aged woman who hasn’t the time nor desire to be married to a wood only boiler. I’m looking to simplfy things. What happens during cold spells? How does the wood get into the firebox if I’m away?" So what do you say guys... how does she keep the pipes from freezing if she doesn't have an automatic fossil fuel backup. Listen to the customer.... I know I'm butting in but I want Gshep to know she is being heard.
Here is a copy of Gshep's email:
Sent: Wednesday, February 20, 2008 6:24 PM
Subject: Benjamin cc500
> Hi Mainewood, I hope you get this email. I really appeciate all the advice
> I've received from the forum. However, I feel as though I'm being pushed
> toward a add-on wood boiler. I'm being told what to take into
> consideration
> but no one is taking into consideration the fact that they don't know the
> layout of my house. Additonally I clearly said early in the exchange; that
> I was not interested in a wood only boiler.
> My house use to be a summer bungalow that was converted years ago to a 4
> season home. The original structure consisted of a walk-in basement and
> bathroom noted as level #1. The chimney at that time was on the outside of
> the structure. Level #2 consisted of kitchen and living room only. Years
> later a garage was added to level #1 and a 2nd bathroom and two bedrooms
> were added to level#2. As a result of the addition the chimney now runs up
> the center of the house because the builder built around it. Based on the
> design of the house; the Benjamin seem as though it would work. I spoke
> with the building inspector, he stated that the one chimney could be used
> for a multi-fuel boiler. He said I would need a permit for the fire and
> electrical installation. With that being said; I already assumed the
> chimney wood require re-lining. Otherthan that the installation appears to
> be cut and dry; take out the old boiler and put in the new; keep in mind
> this is pure speculation on my part.
> A wood boiler needs to get vented somewhere; I believe there are
> restrictions on length and height for the vent. The outside walls are not
> accessible from the current set-up, neither are the windows. So the
> thought
> of adding a wood boiler doesn't seem possible without riping my house
> apart
> to accomondate a 2nd boiler.
> I have already dumped money into my old Weil-Mclain. Its not as efficient
> as the current models and I'm totally dependent on the oil companies and I
> would like to change that. I want to put the money back into my pocket.
> All
> I really wanted from the start of all of this was to know if anyone had
> prior experience with the Benjamin and what I should be concerned with.
> Tarm and NewMac can't accomondate me based on budget and the layout of my
> home.
> Please if you can respond with your experience.
> Thanks
> Gshep
