They do. The low-end output is why I suggested the Fireview. Specs are on their website:That was not the info I was getting on the Woodstock stoves, but they don't seem to have the same range of BTU output as the BKs.
Problem is the size of the existing area he has. All things being equal, I agree, I went with the 30.2 for that reason but I had options, my install area allowed for the larger stove.I would not get a 20 firebox as the low end of the output is quite similar so you don't gain much there, but the firebox is smaller and thus you will have 1/3 shorter burn times.
Helpful priority list, thank you! We won’t have time or energy to chop our own wood for burning this year, but perhaps we can start looking for wood to buy now and put some effort into seasoning it. The price difference is so great that even when purchasing wood, we will be saving a lot of money by using a woodstove this year.Herr Harpspiel,
The information provided by Stoveliker on the inverse heat output and emissions profiles is spot on.
Reading test reports will demonstrate/confirm the information. When you reduce burn rate and decrease air intake, the flow rate through the combustor slows increasing residence time of emissions within the combustor. Counter intuitively, combustors can get much hotter in lower burn rates as a result of increased chemical reaction/conversion.
Secondary combustion stoves typically burn cleanest at their peak burn rate.
Regulators and industry, as well as consumer polling data, suggest 80% of wood burners operate their wood heaters on low and medium low 80% of the time.
This is where "weighted average emissions" comes into play. From all the multiple emissions test done when seeking certification, 80% of your weighted emissions is based upon the units low and medium low test results.
What is important to one person may not be as important to another. Set your priorities, such as:
Possible/achievable low burn duration
Efficiency
Emissions
Appearance
Ease of use
FBV
Etc.
Then once you have your list, look for the stove that most qualifies. That way, with good seasoned wood, you should be pleased.
100% of the 2020 EPA Certified wood stoves are good heaters with varying USP's (unique selling propositions).
As Stoveliker ALWAYS suggests, go cut, split and stack wood NOW. That way, regardless of which model you purchase, you'll get the most from that stove.
Auf Wiedersehen Herr Harpspiel,
BKVP
That's quite normal. There are very few conditions where one would need or want to run on high continuously. Usually, that is a case of a person trying to heat with insufficient BTUs to maintain the temperature in that area.Regulators and industry, as well as consumer polling data, suggest 80% of wood burners operate their wood heaters on low and medium low 80% of the time
And it’s FrauAlthough I am only German by descent, just plain ol’ American by birth.
This is definitely true in general, but it may be easier to find dry wood in New Mexico.It's a bit late in the year to buy wood that will be ready to burn this winter unless it is kiln dried which makes it much more expensive and still doesn't guarantee they cooked it long enough to get it to 20%. Being that you already may have low draft issues and want to burn low and slow in a cat stove, having subpar wood complicates those issues even more.
Alles Gut Frau Harpspiel!Helpful priority list, thank you! We won’t have time or energy to chop our own wood for burning this year, but perhaps we can start looking for wood to buy now and put some effort into seasoning it. The price difference is so great that even when purchasing wood, we will be saving a lot of money by using a woodstove this year.
New Mexico is the third least humid state in the country, certainly drier than Texas. I already bought a moisture meter, thanks for the moisture meter tips.This is definitely true in general, but it may be easier to find dry wood in New Mexico.
A moisture meter is a very valuable tool. In order to use one properly it is necessary to make sure that the wood you are testing is not cold or frozen. (In winter most folks will bring wood into the house for twenty-four hours prior to testing.) Temperature should not be an issue for testing wood right now, though. One should split the piece to be tested and insert the pins of the moisture meter into the freshly split face (most meters specify running with the grain, I believe, but check the instructions of any meter you use). You don’t want to test the ends of a piece or the outside of a piece that is not freshly split.
When we moved to Texas from Virginia about five years ago, my husband and I were shocked how quickly our wood seasons here in comparison to our climate back east. We get much more sun, higher temperatures, and there is simply less humidity. Even very dense live oak can season rather quickly in the right conditions. (Much of our wood is cedar, though.) Back east oak would take at least two summers for us, and that was when we split it small and stacked it near a south-facing brick wall that helped bake it.
I don’t know how New Mexico compares to my location, but you’re farther west of the “dry line” in the country. I just wanted to encourage you to get a moisture meter so that you know where you stand with any wood you buy or process yourself. It is a useful tool for learning how truly seasoned (dry) wood feels and sounds in comparison to fresh/green/wet wood.
You definitely don’t want to try burning wet wood in an EPA stove. It will give very disappointing results. It may be that buying a compressed wood product (Biobricks, Redstone Fuel blocks, and the like) could get you through your first season still more inexpensively than propane. It may not be impossible, however, for you to find dry wood now, though, given your location. Get a moisture meter and start learning what’s available.
hey so, just consider one thing here for that rentable space. A wood burning stove in the hands of someone that doesn't give two craps about YOUR place, could be a recipe for disaster. Renters in general, aren't going to take as much care about a place they own. When you become an owner, you realize quickly how much care and feeding a property needs. When you are a renter, you feel entitled to a certain level of safety and maintenance. That's just how it goes. So if they over feed it, decide they won't let you in to clean it but keep burning it (and they can do that!), again, recipe for disaster.I have settled on the Drolet Deco Nano for this year, reasoning:
We may be really annoyed by the short burn times by the end of the season. If that's the case, we have plans to make a 500 sq ft barn on the property into a rentable living space, so we can transfer the Drolet into the barn and buy the Fireview next year.
- $2k less than the Fireview (factoring in the rebate), and I don't want to commit to a 3k wood stove right now
- Fits better on the existing hearth pad
- Won't be as damaged by less seasoned wood
- Doesn't need the chimney to be as tall - 12' at sea level, I currently have 14' from the stove top, so I'll try it as is and extend if necessary
After some more investigation into the insulation and heat loss of the house and potential energy generated by the solar greenhouse, I believe we will only need about 32k BTUs on the coldest day/night of the year (assuming cloudy, no solar gain), and more like 20k on an average January day. That is to heat the whole house, not just the main living room, and we'll be doing some special wiring on the propane heater so it only runs the fan most of the time, to circulate air in the house. The greenhouse will also have duct work running straight to the heater, so heat from the greenhouse can be circulated as well, using the pre-existing central air system.
