Hello all!
Newbie here looking for some insert recs. Been reading the forums fervently over the past few weeks. Getting a woodburner up and running has become something of an obsession.
House is an A-frame built in '69. Heat pump just doesn't cut it when it's really cold out. We had some $500 electric bills the first year. Smart thermostat and temps set around 65 helped, but we still saw some $300 bills this year, and our main floor was just too cold for us to enjoy. The house has a masonry fireplace with a hearthstove in front. Brand is treemont, label says it was tested in '86. Has 8" pipe out the back hooked up as a direct connect. Originally my plan was to just get the chimney swept and inspected and use the existing stove. I had several different sweeps come out to the house and none of them wanted to touch the thing, saying direct connect is no longer up to code in MD. One quoted me around $3900 to get an 8" liner all the way to the top and said for the same price he could install a new pellet insert and full liner. I'm not really too hot on pellet stoves, (too many parts to break and can't use it in a power outage) and I don't have $3900 laying around. So I'm hoping to go the diy route and save some money.
The house was listed as 886sqf when we bought it. Not sure where that number came from. When I measure it, it comes in at 1600 including the 2nd floor and the loft, or 1138 if you subtract the areas under 5ft in height, 1085 subtracting the loft. I'd like to be able to heat the whole house, but I would be ok if it just heats the 1st floor (875sqf). All the heat seems to rise upstairs anyway...
Chimney is approx 22-25 ft tall. Haven't been able to get up and measure flue tiles yet.
Fireplace measurements:
Hearth: 20.5". Surface is 5.25" above the floor.
Opening: 36"W X 28"H
Back Wall: 27"W
Depth: 23" on the floor, 20" at 28"H
Plan on installing a pre-insulated liner and block off plate. Roof is steep so my plan is to try and push it up from the bottom. Is that doable? Not sure how much flex an insulated liner has..
Considering a stove like century CW2900i. Would that be a good choice?
Other options? A stove with under 3gms emissions qualifies for a $500 grant from State of MD so that would be a plus but not necessarily a requirement.
Thanks in advance.
![Beginner looking for insert recommendation Beginner looking for insert recommendation](https://www.hearth.com/talk/data/attachments/196/196867-51347c0097f386702007d5a31a9491ad.jpg)
Back Wall: 27"W
Thanks in advance.
