Tatnic Corners said:SmokeyTheBear said:Franks said:Tatnic Corners said:As a potential buyer I would want to know if the stove I am looking at is an autoignite or if it was a manual igniter.
doh, good one. How did we miss that??
Because we all know how easy it is to light a stove manually and don't worry about how the fire gets started (in other words we have matches, an approved accelerant and tend to being a bit pyro)
then as an obviously newby idiot do I have to crawl out of bed at 3am to light the stove? or when the stove is going does it stay on until it is actually turned off? That seems like a waste, my gas stove doesn't have a pilot light. If I am going from a wood stove to a pellet because of the "convenience" where is the convenience of having to play with matches? Are the pellets my pilot light?
glad I logged in with questions, and got answered by sarcasm.
Pellet stoves have more than one mode in which they can operate.
All pellet stoves can be manually lit.
Even manually lit stoves may also have more than one way to operate, in constant (you determine the firing rate and it stays at that setting until you change it or turn it off), or high/low mode on a thermostat. Most folks that run on a thermostat frequently change from on/off to high low mode as the heating season gets into full swing.
Some folks also get sick of regularly replacing igniters.
The reason the folks on here generally forget about weather or not an igniter is a must have or even a would be nice to have as that more than a few of us have gone to turn the stove on after doing the weekly cleaning only to discover it won't light because the igniter is not working. A bit of gel and a match or a gas torch can quickly kindle a fire and get things back to heating. During the heating season a stove is likely to be on for at least a week at a stretch, sometimes longer (depends upon the stove and the fuel you are burning).
. One exception is the Euromax. It was advertised as a "fast" self starter, and boy it is. I never got around to timing it, but it seems like only a minute or so from pressing the start button until you see it start to burn. I guess I should time it some day.
