We are finishing a poured concrete, "walk out",  basement, and installing a Hearthstone "Heritage" stove there. The finished walls are framed, insulated, and drywalled, and a "four season" addition has been added at the "walk out" end of the basement.  Anticipating the wood stove, we left a 6 foot section of the exterior concrete wall near the "walk out" end of the basement unframed and uninsulated.  With the addition, the concrete wall on the "walk out" end of the basement is now an interior wall, and is also unframed and uninsulated.  The stove will sit in the corner, close to the concrete walls, with its back to the exterior wall (about half above grade) and it's right side close to the "interior" concrete wall.  When I thought of this placement I was thinking...concrete walls...thermal mass...heat retention...good, good, good.  Now I'm beginning to fear that the exterior wall will be more of a heat sink, carrying heat away from the stove  and into the ground and the outside air.  Is this something I should worry about?  Should I consider a heat shield on the back of the stove, or insulating the outside of the basement wall in that section where we didn't insulate the inside?  Any advice would be appreciated.
