Because I didn't want to. I tried to talk him out of this set-up and go with a class A chimney system. But this guy was "cheap"!Why didn't you install said liner for your best friend
And that door is for the ash drop on the fireplace correct? It would be allot of work to put in a clean out and would not be worth it at all you have the right idea just clear a little bit so you have enough room and you will be good.The chimney's clean out is a good 4 plus feet below the thimble level and it's the "60s" style steel door with no seal what so ever.
How could you possibly confirm there is no air getting into the system? There can be gaps in liners open block cores in the crock and cleanout and lots of other potential areas for air leaks in an old clay lined chimney. Not to mention the door which is usually not sealed well at all. And regardless to pas the ul tests that liner system needs to be a sealed system separate from the rest of the chimney Which if you leave the tee cap off it is not.the clean out is an extension of the liner also and if no air is getting in then it is a sealed system
So you are going to install it start a fire and get everything up to temp so you can test the draft and if you dont have enough you are then going to pull the liner and put the cap on? That would be much easier than just putting the cap on to start with.That's why they make draft gauges and such
Two separate incidents within a week or two.Word. Also if the air from clean out was by passing the stove completely how did the stove over fire to begin with considering it obviously had no draft
Yes just for the fireplace. Other flue is sealed up from clean out location.And that door is for the ash drop on the fireplace correct? It would be allot of work to put in a clean out and would not be worth it at all you have the right idea just clear a little bit so you have enough room and you will be good.
