There it is... it will only cool the flue enough to control the draft to the point of being the correct.Does the baro damper’s injection of such a small amount of room air really cool the flue that much? It doesn’t take much of a “leak” to really spoil the draft. Properly adjusted, are we talking about 100 degree drop, 10 degrees?
And I can't tell you how much it cools the flue...just that these warnings of creosote buildup after the BD have not been my experience...just the opposite actually...pipe seems a little cleaner after the BD...dilution maybe?
So for me, I see no real "risks" in having a BD...got to have creosote to have a fire...and my Kuuma makes none...and then even if there is a fire, a properly insulated flue should take it. A lower "risk" than running with high draft and ruining a $6k furnace...which isn't so much of a risk, as an eventuality.
The only downside I see is the need for makeup air to feed the BD...but not a huge issue in most basements.
![[Hearth.com] Barometric Damper [Hearth.com] Barometric Damper](https://www.hearth.com/talk/data/attachments/268/268688-ec2cb59fb320753a728387d5f7c2372e.jpg?hash=T7189JqbXW)
![[Hearth.com] Barometric Damper [Hearth.com] Barometric Damper](https://www.hearth.com/talk/data/attachments/268/268689-dc0456be001c891dc1276009687cdee0.jpg?hash=jmF_ZHnPDI)
![[Hearth.com] Barometric Damper [Hearth.com] Barometric Damper](https://www.hearth.com/talk/data/attachments/268/268690-1121241274153e8ace46e9e9452a2a4d.jpg?hash=gUK5CeHUSj)
![[Hearth.com] Barometric Damper [Hearth.com] Barometric Damper](https://www.hearth.com/talk/data/attachments/268/268691-825009d5a988c9a1e2ed604b5fc571e9.jpg?hash=t2r3l9PdIi)
![[Hearth.com] Barometric Damper [Hearth.com] Barometric Damper](https://www.hearth.com/talk/data/attachments/268/268770-ea1a83cbf5b254e1c08798d945e67641.jpg?hash=KAaRNZvgNc)
