Ok im ready to throw this thing out the door. I have it set at -.03 with a manometer but it is cooling down the flue way to much. It is 500 degrees before and 250 less the 18" after damper so needless to say im having a creosote problem. My furnace has a draft inducer on a thermostat so this is required by the manual. So here is my questions.
#1
Should i close damper once a day when i burn hot to help clean the pipes?
#2
Since the draft inducer is only being used after a reload could i get away with a key damper?
I have 31 feet of chimney so i have a very strong draft and i really like the new furnace but this problem with the barometric damper is giving me fits.
#1
#2
