I was reading with inertest all of the ideas for backup power to run our boilers. I thought I had found the solution in the Tripp-Lite APS line of inverter/charges. These units operate as a UPS, passing house current though when online and switching to the inverter when the power goes out. There is a charger to maintain and recharge when the power comes back on. I thought this would be ideal providing instant backup, and allowing me to run the generator intermittently, to run the pump and recharge the battery bank.
However I called Tripp just to double check before purchasing a unit. The said the in order for their charger to work it had to have a computer grade wave form, otherwise it would damage the charger. I’m sure my Troy-bilt portable generator is not producing computer grade power.
Guess what I could do is unplug the unit before firing up the generator but it kind of spoils things not being able to recharge the batteries. I suppose I could lug them up one at a time to charge directly off the generator but its only charging at 10 amps, hardly enough to put back what I’ve taken out.
Has anybody actually used a Trip-lite unit with a generator?
