I just received my new dual temp gauge .The web site I bought from stated 10 foot leads , in actuality they are 10 INCH . Can I use standard thermostat wire to extend the lines from the the thermocouples?
nofossil said:You might have a problem. Thermocouples work due to an effect that you get whenever you connect two dissimilar metals. Thermostat wire would introduce additional junctions with another dissimilar metal. If it were me I'd try it, but don't be too surprised if it doesn't work. You can buy thermocouple lead wires - just make sure that you use the right ones on each leg, because they're different.
sdrobertson said:Generic question - do most controllers(meaning the "box" that displays the digital temp) use the same signal between thermistors and thermocouples? Can they be interchanged or do they need different controllers? When I go shopping for digital temp gauges what am I supposed to look for so I know what sensor a certain unit uses?
sdrobertson said:Thanks - now its a little clearer. I understanding now that I need to look closer to what I'm purchasing and what will be compatible with what. Someone would be able to retire confortably if they came up with a "plumbing for wood boiler with storage in a box" kit that would control inlet and output temp with included control and temp reading in a easy to use kit. Purchase boiler, storage(open or closed) and "PFWBWSIAB" kit - three hours on the weekend and your set for 25 years of free heat.
nofossil said:sdrobertson said:Thanks - now its a little clearer. I understanding now that I need to look closer to what I'm purchasing and what will be compatible with what. Someone would be able to retire confortably if they came up with a "plumbing for wood boiler with storage in a box" kit that would control inlet and output temp with included control and temp reading in a easy to use kit. Purchase boiler, storage(open or closed) and "PFWBWSIAB" kit - three hours on the weekend and your set for 25 years of free heat.
I've had more than a couple of inquires about packaging the NFCS (NoFossil Control System). With my luck, someone would install it, burn down their house, and sue me.
!! Or the Birchwood-Casey .22 swing target I bought this morning to use for target practice with my son, which has a big disclaimer on the package that the Mfgr has no control over the end-user's use, and so disclaims all liability for outcomes.nofossil said:At the risk of being pedantic (gotta love 'pedantic' - it's its own definition, kinda like 'eschew obfuscation').... wait a minute - I just created a sentence with 'its' twice in a row, that's actually grammatically correct!
