I
		imacman
Guest
I have mine set at 2-5-1 and Hi-Lo also, and have been burning mainly Stove Chow & Greene Team, with a little Somerset for the real cold nights..... When I switched the stove from On off to high low, the room air fan would stay on all the time with AWF, but when I was burning Presto Logs the room air fan would occasionally kick off because there wasn't enough heat. For the record, the 10-CPM was at 1-9 when it was in the "low" setting and the bottom buttons 2-5-1......
But I had the same problem last year burning the horrible North Americans (aka Curran) and CleanFire (aka NEWP)....just not enough heat to keep temp sensor satisfied.
I never run my room blower at 9, partly because there's no change past 7. You might try lowering it to 6 while burning the Presto's.....might keep a tad more heat in to keep the blower running.
