I think the effergy is cheaper.  There may be other ones out there too.  They all involve putting current transformer coils on the hot legs in the breaker box.
			In my quest to check if I had any well leakage i pulled the cap on the well. There was some bubble wrapped shoved in the 1st few feet of the casing. I pulled that out and could hear gurgling. Nothing noticeably leaking at the pitiless adapter. I shut the pump down and drained the system. The gurgling still was present. Put the well cap back on (left the bubble wrap out) and now it is hissing! Fairly loud to. This is with the pump still off and the system drained. I have had it off a few hours now and it's still doing it. I would have thought that it would have quit or drained out by now if it was a bad foot valve. Well pump sits at 357'
So short of buying a $300 tool. How would one test for "leaks"? I plugged a kill-a-watt in every 120v circuit and didn't get anything out of the ordinary. So how would I rest my 220 circuits?
So the well is actually blowing air. There is a vented cap on the well but the PO had it siliconed on with the vent/wire tube also siliconed up ( looked like a tube of silicone in there) . I had the pump off and system drained and it continued to blow air for 3 hours. So no change from pump on or off. I don't know a lot about wells but I would assume that if it needs vented and they had it sealed it can't be good. I did adjust my pressure switch. The tank had 30lbs and the switch was set to cut on at 38lbs. The well has a 1.5hp 7 gal/min pump. Once it kicks on it takes a little over 2 minutes to pump up.Now we're getting somewhere. Your well should be silent when the pump is off. I've seen several well pipes develop leaks between the pump and the pitless adapter. This causes pump cycles when no water is being used. Also, 357 is quite deep and depending on the static water level you might have to use a lot of power for water even when everything is perfect.
Tonight, shut off the well pump breaker and note the pressure, no water to be used. In the morning the pressure should not have dropped at all unless somebody used water. If morning pressure is zero, go listen to the well and I bet the gurgling is gone.
I can hear the pump kick on from the living room. It's certainly not cycling. I'm just wondering if it wasn't straining if it should have been vented and was plugged. I'll look into the monitor.My energy monitor is what alerted me to a rusted out check valve down on my submersible well pump. It would pump up the bladder tank, shut off and then the water would leak back down into the well. Over and over and over. When the electric usage went nuclear I went down in the basement and sat down for a bit and listened to the pump come on, go off for a little bit and kick in again.
It says it will hold 17.7 gals at 30psi bladder pressure. I figured with a 7 gal min pump , 2 min was about right?How big is your tank? 2 minutes seems too long.
Maybe valve off all water to the house to eliminate leaky toilet valves and the like?Do the test. Shut off the well pump overnight,use no water, and check for pressure loss in the morning. This is how you identify a leak.
I'll do that tonite. The pump is not blowing air the well casing is. I can put a lighter over the casing and it will blow it out. With the cap on it just whistles/hisses. That was even after the pump was off for 3 hours.Your pump is not blowing air but the water level in the well will rise and fall as the pump cycles which can move air if there is a vent. There is no need tojust accommodate this air movement with a vent because the well can only pump water and water comes in from the bottom. You don't want crap or surface water getting in to the well.
I adjusted all the toilets today and put them all 1" below the overflow. At least one of them could have been high. I did have the kill o watt on the fridges . I wrote it down several weeks ago and now I can't find it. I'll put it on there again and check. One strange thing which from what I searched is common, when the furnace is off it still energizes a transformer. Doesn't amount to much (comes out to 5.4 kwh month, .47 cents).Maybe valve off all water to the house to eliminate leaky toilet valves and the like?
I bet that water heater is gonna be a winner.
Did you plug the garage freezers into a kill-o-watt meter for a period of time, like a week?, at cold ambient temps to get a trusty kwh consumption rate?
The flapper could still be leaking. If you have a shutoff valve for the house, which you should, why not turn it off while you're doing the pressure tank leakdown test overnight?I adjusted all the toilets today and put them all 1" below the overflow.
I'll do that to. If they are leaking it would have to be minute. I put some food coloring in the tank and nothing showed up in the bowl.The flapper could still be leaking. If you have a shutoff valve for the house, which you should, why not turn it off while you're doing the pressure tank leakdown test overnight?
This is exactly what my well is doing
That sounds cheap...NOT. Good luck.Shut the well pump off and the pressure gauge was 0 this morning. So I've got an external leak some where. Guess I better start another thread while I wait for the well guy to show up!
I had the house valve off last night. I'm pretty sure it's not in the house unfortunately. I have access to all the plumbing and nothing is leaking and I also tested the toilets with food coloring and they aren't leaking.I would do the overnight thing again, but also valve off the inside-the-house stuff. Then if it's zero again, it's in the house. If not, it's in the ground.
Actually wouldn't need to be overnight, a couple/few hours should show a pressure drop. Long as no water was otherwise used.
