I have an Avalon Astoria stove. My stove does not want to run on the lowest level. (1) when I try to run it on the level it will run for maybe two hours and then fault code green with happen and stove will shut off what could be happening?
When was the last time you cleaned exhaust venting, internal smoke pathways, combustion blower chamber? Low burn tends to collect more ash because of the lower combustion blower speed. Pellets that burn with higher ash content will make it clog up sooner.
Green fault means constrictions in exhaust pathways from ash... page 34, 35 of the manual. You should get a new gasket for the combustion blower before pulling it apart.
