WE HAVE A AVALON MODEL 900 I THINK IT ABOUT 17 YEARS OLD (CAME WITH HOUSE) MOVED IT LAST SEPT TO PAINT,WAS WORKING FINE,DID NOT TIP OR PUT ON ITS SIDE JUST SLIDE ON FLOOR. NOW WHEN TURNING ON THE AUGER WILL NOT TURN,REMOVED THE MOTOR ,BENCH TEST,WORKS FINE,TURNED AUGER BY HAND,THAT WAS OK,JUMPED VACUME SWITCH,THAT DID NOT FIX THE PROBLEM,CHECKED FOR BROKEN OR DAMAGED WIRES NONE FOUND.REPAIR MANUAL STATES MAYBE CONTROL BOX,REMOVED BOX,CHECKED FOR FUSE NONE FOUND,OPENED BOX LOOKS LIKE 2 SMALL TIMER/RELAYS INSIDE,IS THERE ANY WAY TO CHECK THEM, MANUAL STATES TRY NEW CONTROL BOX BUT AT $180.00 I WOULD LIKE TO TRY ANYTHING I CAN FIRST.
THANK YOU
THANK YOU
