pretty much sounds like the timing chain slap- sounds a lot like noisy lifters. 2 fasle and one for the road starts -yep- priming the oil pressure so the chains become fully tension-ed. As I said the earlier versions had keeper ratchets on the tensioning systems but some ford engineering genius decided that that was putting to much continuous pressure on the one bearing behind the cam ( there failure reports)phasers. So the second generation is sans the ratchet. This problem is not unique to Ford, Gm has it also.wow sounds like not a fun field to be in anymore. i remember the days when i could make a carb car run as good as a fuel injection car when it was cold and felt great at the end of the day. i think a steam engine might be the way to go. could even use some of my wood instead of high gas prices.
back to the spark plugs for a sec. now i'm worried about that. i wanted to change them this past summer but was pulled in 5 different directions all summer long. so when i go to change them they might not come out? or do they break in the hole?
listening to this noise my ears are telling me maybe it is a lighter sound then crank bearings. i did find a way around this until i change the oil again two key turn overs. shut off the key before it starts the on the 3rd key start it. it seems to key the noise at bay
