I have never seen that but it is interestingApparently it is common for them to buy a commercial furnace and replace the electrical damper system with a bimetallic thermostat to open and close the intake.
Gravity ducted.
Pretty wild!
Gravity ducted.
Pretty wild!
Yeah it takes a while to learn a new setup as well. I change stoves pretty often but I like the challenge of figuring it out.You want automatic, precise control of the house temperature. The control needs to have multiple negative feedback loops. With many sensors. Room temp, room set point, stove temp, outside temp, air control position. I think the control needs to alert you when it needs more fuel. And then some AI would be helpful. Not easy software.
But the seasoned wood burner can take in all the variables and set the air control. We all know when you don't get it right the house is cooking or freezing.
I thought I remembered seeing something like that in an add a long time ago, which made me think that something better should exist by now.There used to be several bimetallic coil thermostats available which could be added to a wood burner to control the intake air in response to stove temperature. The Amish like to add them to furnaces in place of electronic controls. Even Condar made one at one time.
Little box with a dial and a chain hanging out to lift the flap.
It might be crude but beats having to futz with the air control if you want to do other things AND would like the stove to be somewhat controlled.
Ideally your stove is designed with a thermostat like the BK but that is very rare.
I believe that electronic controls are coming to stoves but not yet!
I’d be interested in seeing the set up.I built one for an Englander nc-30. It worked ok but there are certain times (circumstances) that I needed to manually control it or over ride it. It was a bi-metallic coil set up.
Once you learn your stove and get comfortable with it it really doesn't take much time at all. With dry wood I am usually up to temp and shut down in 15 mins or so. I then don't touch it again for about 8 hours. And that goes for the blazeking I am currently running and the quad and regency I ran before that were similar to your stove.Thank you for all the advice. I’ve only had the stove for a month. So I still have a lot of learning to go I’m sure.
im finding out that a wood stove takes up a lot more time then a central air system. So I’m trying to save as much time (of sitting in front of a stove) as I can. Also I want to reduce over fires and creosote as well.
(the biggest reward of a wood stove is a happy wife) and maybe the only one
Only if you buy the premium version with the auto-reload robot. ;-)I'm waiting for the Smart stove control that I can adjust with my smartphone from work!![]()
It’s not that I’m trying to get exact room temperatures, but I’d like to be able to run my stove at either a low medium or high burn temperature, And then keep the air inlet wide open so the coals can burn down.You want automatic, precise control of the house temperature. The control needs to have multiple negative feedback loops. With many sensors. Room temp, room set point, stove temp, outside temp, air control position. I think the control needs to alert you when it needs more fuel. And then some AI would be helpful. Not easy software.
I just got thinking: what if I took a spare firebrick and stuck it on top of the baffle blanket, under the liner inlet, inside the stove? Could that help restrict the the opening a bit, or is that not a good idea?
Why do you want the coals to burn down? I usually want the coals to last as long as possible then reload.then keep the air inlet wide open so the coals can burn down.
I usually scoop the ash off top. I guess I am a little spoiled when the stove is too full I fire the other one up lol.Then those stupid coals don’t make enough heat to keep the stove hot and accumulate to the point that you can’t put more wood in for heat.
Some people actually scoop them out and throw them in the snow to make more room for fresh fuel.
More specifically, the excess caols. In the morning there tends to be a partial log or at least a lot of caols that are black in the back end of the stove, While the front of the stove has plenty of luke warm coalsWhy do you want the coals to burn down? I usually want the coals to last as long as possible then reload.
My neighbor showed me how to make a great coal/ash sifting scoop. In the morning I sift out( in the stove) about half the ash while keeping all the coals in the stove. Then I scoop out the ashes to a can with a lid. I can keep that can in the house putting off more heat till it completely cools.A long cool burn down of coals is great when that makes enough heat to keep your home warm. It really gives you a long burn time and less reloads per day.
Things change when it’s cold out.
I don’t think I’m asking too much my stove. At least not on purpose. It’s keeping my basement and first floor of my house close to 80°. Which is more than I would like. My goal is to run it at a lower temperature with a longer burn to Keep from using up so much firewood. I probably should mention that at this point all I have access to is Elm and Maple. Hopefully by this time next year I’ll have a lot more hedge in Mulberry on handIf you can take the coals forward then we’re talking about different things. You can fill the fire box 3/4 full of nothing but glowing coals when you’re really wanting the heat. It’s actually a great sign that your stove is undersized but also a great sign that you’re just asking too much of it.
In my house stove and my climate, I really appreciate the cooler coaling part of the cycle. It averages out with the hotter early parts of the cycle to keep us comfortable.
I’ve learned that when you have access calls you can pile them towards the front of the stove and lay a soft wood log on it and they burn down pretty quickly. But I haven’t been through a cold winter yet. Round here it’s still in the 30s at night
It’s mostly ash with quarter inch size coals mixed in it. Can has a tight lid and it doesn’t get hot enough to even make the factory finish smell hot.Not trying to be critical but.....Don't believe I'd be keeping a can of hot coals anywhere in my house until they cooled? Unless I misunderstood your post?
