shut my stove down 2 weeks ago. Stove was working fine no issues. I just went to restart it. Normally when I turned the stove on the auger light would come on for maybe 5 seconds, go off for maybe 3 seconds, then come back on for 5 seconds. depending on the speed I had it set at would depend on how long the light stayed on. When I attempted to start it this time , I turned to power switch on,no auger light. I scratched my head for maybe 30 seconds. Auger light came on and went off very quickly. It blinked on/off,on/off very fast for maybe 3 min. I shut the stove off. Unplugged stove, pulled it off the wall, plugged it back in, turned it on. Auger light started to blink on and off quickly. The auger motor shaft was turning,but quickly with the blinking of the light. I assumed I had power, but checked it anyways. outlet power at junction board for power cable, fuse has been bypassed by previous owner but I do have power on the board at both ends of the wire. The brass wires exposed on the auger motor have 70 volts on each wore. I checked power at the on/off switch. At first there was 14 volts on both legs of the on off switch wether it was in the on or the off position. I rechecked at had outlet power on both legs(maybe my meter leads were not in tight initially) with the switch on or off. I unplugged the stove, waited 15 min, plugged it back in, turned it on and now no auger power light. Any suggestions as to where to start?
