I have a Vermont Castings 2550 Encore, c. 2010, and the refractory has some pieces missing.
My son has some high temperature board that was in the scrap bin at his work - he works on high temperature industrial furnaces.
I'm going to use that material to patch the refractory temporarily, and in the off season will decide whether to replace the refractory or get a new stove.
The two pieces will be 10" by 3-5/8" wide by 1" thick and 14" by 3-5/8" wide by 1" thick, so they will cover the entire missing sections easily. My initial intention is to use sheet rock screws, which is how the refractory you order from Vermont Castings is bound together.
Are sheetrock screws the best way?
If the rest of the refractory is too crumbly and the screws don't hold, is there another way to hold that in place? Will gasket cement work on this stuff, or will that not hold at all (I can use gasket cement if that'll work better). Is there anything else that I can use other than a sheetrock screw??
