Hello all,
I wanted to take a minute to brag on this stove and see if anyone has any information on it.
Some of you may recall but I got frustrated with my set up mid season last year and wound up changing out stoves. I removed an insert and tried to revive an old Ashley I had inherited. I was not happy with the smoke spillage from the Ashley and came across a deal on this Huntsman and gave it a shot.
I installed it and was able to use it for about 2 solid months of the heating season and I am very impressed and happy with it. I do not think it is a 241 due to it not being a step top though it measures out roughly the same. The firebrick pattern is almost identical to a Fisher Mama Bear and it holds roughly the same amount of wood. It has the 3 air adjustments and with the bottom two closed and top open 1 1/2 turns easily burns 8-10 hrs with an easy reload the next morning. Puts out a ton of heat keeping the finished basement very warm even with stairway open to the main level.
It has an opening roughly 10x10 between the top and bottom chambers with a 6" rear outlet hooked up to a 30' 6" liner. When I cleaned the liner after 2 months of solid use I had less than a cup of buildup.
I made a makeshift baffle closing up about half of the 10x10 opening using firebrick and it did help clean up the smoke coming from the chimney and I plan to tinker with that this year and see if I can improve it any further.
Any additional info on this stove would be appreciated. I have scoured the web and can not find any info on this stove. Tons on the 241 model but nothing on this one.
![ASW Huntsman ASW Huntsman](https://www.hearth.com/talk/data/attachments/183/183787-3979e32a1fa0318fcc66c8f895392c57.jpg)
![ASW Huntsman ASW Huntsman](https://www.hearth.com/talk/data/attachments/183/183788-c36ca2323703cacd8ca309e30cf3cb50.jpg)
