I HAVE OWNED AN ASHLEY PELLET STOVE FOR THE LAST FIVE YEARS AND IT HAS PERFORMED REALLY NICELY. HOWEVER, RIGHT AFTER CHRISTMAS OF 2020, THE AUGER GOT JAMMED UP AND STARTED TO ELONGATE THE HOLE FOR THE SHEAR PIN. I CLEANED OUT THE STOVE, DUMPED THE ASHES, AND UNJAMMED THE AUGER AND STARTED IT RUNNING IT AGAIN. IT RAN FOR 2 DAYS AND JAMMED UP AGAIN, AND THIS TIME THE SHEAR PIN SHEARED THE SHAFT OFF OF THE AUGER. I CALLED US STOVE AND THE SECOND TECHNICIAN THAT I TALKED TO, SENT ME AN AUGER, SHEAR PIN, BUSHINGS, AND MOTOR AND THE TEMPERATURE SWITCH AT THE EXHAUST FAN, ALL FREE OF CHARGE. THAT WAS REALLY NICE OF THEM, BUT IT TOOK THE ORDER 4 TO 5 WEEKS TO GET HERE. IN THE MEAN TIME I USED MY MILLING MACHINE TO DRILL A 1/2" HOLE WHERE THE SHAFT WAS AND MADE A SPINDLE TO GO INTO THE AUGER AND PINNED IT IN THE AUGER. THIS RELEIVED MY HEATING PROBLEM FOR THE TIME BEING, BUT I NOW HAVE TO CLEAN MY STOVE OUT EVERY 2 DAYS. WHEN I FIRST BOUGHT IT I COULD GO 3 TO 4 WEEKS WITHOUT CLEANING IT. I HAVE NOTICED THAT ON THE SECOND DAY AFTER CLEANING, THE FLAME GETS "LAZY" AND THE FIRE BOX STARTS FILLING UP. THIS IS WHAT WAS CAUSING MY AUGER TO JAM UP, BECAUSE THE PELLETS WEREN'T BURNING UP LIKE THEY WERE SUPPOSED(LIKE THEY WERE STARVING FOR AIR) TO AND THEY WOULD FILL UP THE BURN BOX, THE CHUTE THAT THE PELLETS DROP OUT OF, RESULTING IN THE PELLETS CRAMMING UP THE TOP SIDE OF THE CHUTE, CAUSING THE AUGER TO JAM AND BREAK. I HAVE NOTICED THAT THERE IS AN AIR FLOW PROBLEM CAUSING THE FLAME TO BURN CALMLY NOT LIKE THERE IS AIR FEEDING THE FLAME. I HAVE CLEANED OUT THE EXHAUST CHIMNEY WHICH IS 3 FEET STRAIGHT OUTSIDE MY BASEMENT WALL. THE INTAKE IS ABOUT 3 FEET LONG ALSO WITH NO OBSTRUCTIONS. I HAVE REMOVED THE FAKE BRICKS AND THE PANELS BEHIND IT AND CLEANED ALL THIS AREA OUT. I HAVE REPLACED THE TEMPERATURE SWITCH BUT I AM HAVING TO STILL CLEAN IT OUT EVERY 2 DAYS. DOES ANYONE HAVE ANY SUGGESTION ON HOW TO REMEDY THIS PROBLEM.
