I should say, Green and Black are like soft Maple. There are a lot of varieties and I think some of them are pretty high BTU....
I didn't know guys...I didn't realize it was so good. I can probably get cords worth this fall and leave some of it in log form as long as rot isn't a big issue. I can probably split a cord or two for this winter.
I don't know how much 10 trees produces. It has the ash borer, which is why he's getting paid to take them down.
I like fast seasoning wood. I have lots of oak...but it's not ready. It smells nice though when you are near the stacks.
That's okay that you didn't know firecracker. We all have to learn and keep on learning. As for the ash, it makes up about 99% of what we've burned since 2002 or 2003. We still have plenty of it to cut as all our ash trees died. We have enough on hand already to take us somewhere around the year 2020.
As for the wood rotting, forget it. I've still got some ash wood on the ground that has been there for many years and it has not rotted. I found some one year that I knew had laid there 2 or 3 years and most of that time it was in water. It was fine after it dried out. No rot at all.
Although we've been cutting mostly ash since around 2002, we have just started running into a very few that is showing some punk and we've had only two trees fall on their own. They were still good for burning and are in our wood stacks somewhere. This coming winter we'll be burning ash that was cut during the winter of 2008-2009. It will warm us wonderfully.
Get all you can and you'll also be amazed at how easy it is to split.
I'm glad it is rot resistant. I'll try to take it all from him then.That's okay that you didn't know firecracker. We all have to learn and keep on learning. As for the ash, it makes up about 99% of what we've burned since 2002 or 2003. We still have plenty of it to cut as all our ash trees died. We have enough on hand already to take us somewhere around the year 2020.
BL and ash mix is great heat.Good stuff! Second only to Black Locust in my opinion.
My next door neighbor alerted me to the purple box traps the town has set to attract the Emerald Ash Borers. I have to check to see if they have made their way to New York.
If they are decent-sized, not real big, I figure somewhere around half a cord per tree as a ballpark figure. Most of the dead White I cut is mid to upper 20s MC. Definitely needs to be stacked several months but it seems to dry pretty quickly. Like HDrock said, the tops might be almost there. I probably have a more damp climate that Dennis, and the Ash will start to punk out if it's on the ground for real long. Even then, I can usually cull out the punk and get a lot of good wood. I like to grab it when it's still standing but even then I might run into a little punk. If there is substantial punk starting, it will absorb rain moisture in the stack. If you get it stacked now, it might burn pretty decent at some point this winter. And don't forget to post the pics.10 ash trees makes up my 14/15 wood. Cut and split this spring, they gave me about 3.5 cord.
Ash is great, but I disagree on dead ones being ready to burn that day. I've cut many, many dead ash the last few years and haven't found any I would want to throw right in the stove. It's pretty darn good after 6 months, though. Give it a year, and you'll have some perfect firewood.
I can absolutely say , you can burn some standing dead ash the same day, I have done it more than once, not a 20" trunk ! but the top half of the trees and smaller ones.10 ash trees makes up my 14/15 wood. Cut and split this spring, they gave me about 3.5 cord.
How many cords a year do you use if you are that far ahead on your wood supply?
Because, after all, I have cut many, many dead ash the last few years and haven't found any I would want to throw right in the stove.I've cut many, many dead ash the last few years and haven't found any I would want to throw right in the stove.
What would you guys do if you had a lot of healthy Ash trees with the threat of the EAB coming to your area? I'm considering cutting more Ash now and leaving the other species for the future.
We had the purple boxes two years ago in the eastern part of NY and I believe they did not find any. Since then, I haven't seen anymore boxes.My next door neighbor alerted me to the purple box traps the town has set to attract the Emerald Ash Borers. I have to check to see if they have made their way to New York.
