Ashful
If you rake the ashes thru each day, then yes. But I found that just leaving them alone and letting them naturally fall thru the grate seemed to keep the right amount of ash in the belly, and slowed my required emptying schedule. I’d normally empty each of mine (I was running multiple Jotul Firelights) twice per week, when burning 24/7. I was burning mostly walnut and ash, in those years.the issue I had with the jotul is, During heavy burning season it had to be emptied just about every other day. If you forgot, you made a big mess when the pan is removed.
Does that little opening really work on the BK in terms of ash removal. I have a hard time imagining it. Hence the bucket and shovel purchase.
Also, the opening nor the actual ash pan has no seal, it just sits there (no gasket). Is this air intrusion considered epa hole?
In my opinion, ash plug systems all share the same fatal flaw, it’s impossible to rake ash down the hole in a hot stove, without raking a whole lot of hot coals into the hole. As a result, my pans would be so damn hot that the handle would burn me even thru my hearth gloves.
My solution for the BK Ashfords was to get a 4” round cast iron shower drain style grate, which I drop in the hole when I remove the plug. It’s a perfect fit, and ends up flush with the brick floor. Then I can just rake the mess of ash and coals across this grate with an ash rake. The ash falls thru, the coals stay in the stove.
Others have talked about using a basket to sift the ash from the coals, to make these ash plug systems work for them. Seems like a lot of work and mess, but I’ve not tried that.
No issues with the plug leaking, that is where it’s superior to Jotul’s ash grate system. Once that plug is dropped in place, and ash compacts around it, there is no way it’s going to leak.
