That link worked fine for me, Dennis.
My door only opens to 90*, then it hits the fireplace front wall. My shovel is the normal size but I want to be able to shovel with my right hand and then spin the shovel and dump with the (short, cut-off) handle pointing out into the room (shovel would be parallel with the door side of the stove.) I'm going to fashion a simple pan that is about level in height with the bottom of the door opening. I think that will work well...and I can save $102.
The Ash Dragon looks good; Scoops 'em
inside the stove which would make it easy to avoid any flying ash. Only problem is, it costs money too. :lol: Another thing I don't like about shoveling is that you might be able to push most of the coals out of the way but you always get some glowing chunks in the pan. With the Keystone's ash pan the only thing you remove is cold ash. All the coals burn up in the stove since they can't drop through the grate until they are quite small. I don't like throwing even a few BTUs out.
To me, the Fireview would be the perfect stove with an ash pan and big glass...
Life is as baffling to me now as it was when I was a boy. Growing older didn't help me figure anything else out, and emptying ashes is no exception. :lol:
