I was told by a friend, who has heated his house with wood for years, that ash wood can almost be burned as soon as it's split. Is there truth to this?
Thanks.
Thanks.
Kilted said:I have Modesto Ash around me. It's true as long as you split in April stack where the temp reachs 90F-100F in the summer, you can burn it in December.
A friend of mine gets his oak delivered in March splits any extra that's needed spreads the oak out 1 stick deep on his black-top driveway stacks it at the end of summer and burns it starting in November. The black-top will reach 90F+ every day during the summer.
-- Brandy
derbygreg said:And the approximate moisture content of freshly cut ash is around 17%. I believe we consider wood seasoned if it is under 20%.
Arlo said:Ive got a chord of ASh from a tree that cme down across the street this summer. It had been dead for 2 years and the town took it down and left the wood. I'm using oak and hard mix first and saving the Ash for the cold weather (January /Febuary). It burns beutifully, hot and slow.
Quercus?? not Fraxinus?? :cheese:Quercus said:Green ash got its common name about 200 years ago because one can burn it green.
derbygreg said:https://www.hearth.com/econtent/index.php/forums/viewthread/10703/
We have covered this one before. Excellent wood. Watch out for the Emerald Ash Borer
http://www.ashborer.com/
an evil little bug
I can speak only for white ash, but as good as it is, do not expect it to outperform oak. I burn a lot of ash and will continue to do so but if I were to save something for the really cold weather it would be the oak. You might want to rethink your plan a bit.
