I would have thought that mod would just close off the primary air with the secondaries still wide open?
The Lopi draws both supplies from the same manifold below the insert. Removing the factory stop bolts allows the slider air control to fully close over both holes. The slider is spring loaded against the stove, so it seals very well. I put in a lower stop for normal use, so I know where the factory stop is, but to override that I just need to lift the knob slightly to raise the slider over the stop.
Pictures say a thousand words: https://www.hearth.com/talk/threads/lopi-freedom-air-modification.107105/
TE
