Are these decent options?
FunkDaddyG
16
Blueridge Mountains
I am considering getting both of these two Drolet stoves. I need them to start and stay lit without problems, the heat and burn time to be regulated without difficulty within their limits, and hopefully durable. Are these viable options?
drolet HT-3000
(factorypure.com/products/drolet-ht-3000-epa-certified-2-700-sq-ft-wood-stove-new)
Drolet escape 1800
(factorypure.com/products/drolet-escape-1800-epa-certified-2-100-sq-ft-wood-stove-on-legs-with-black-door-new)
We’re on a budget, we have 3 stoves currently, an older fisher that works great but two newer wood stoves that won’t stay lit unless they’re burning full tilt and are a pita to get started. Weve cleaned them several times without success. So we need better stoves that don’t have to have the door propped and watched just to get it going.
We live in an old drafty uninsulated house that we struggle to keep warm in the winter.
Any helpful inputs?
Drolet/Osburn make very good products. My fear is that to me it sounds like you might have a draft issue and that hooking up a new stove may not solve the issues you are having. Currently what kind of chimney do you have? Does it have a liner, is it insulated? Others will be along with far more knowledge than i have and any more info you can provide will help.
This sounds like wet wood. A new stove may not be the solution you are looking for if you feed it sub par fuel. What moisture content is your wood and how do you measure it?
Reactions: stoveliker
I agree with that ^^
The good news is that the solution is free: let your wood dry for two or three years (split, stacked off the ground, and top covered).
Stainless steel liners, 6 inch, insulated and properly installed with 22feet length per chimney
How do you know it's dry?
How and how long was it seasoned?
The wood is seasoned properly and dry
You could be right about that. But getting a moisture meter and testing the way I outlined above (test the freshly exposed face of a freshly split piece at room temp with pins parallel to the grain) would let you know for sure. Moisture meter is under 20 bucks so it could save you buying 2 new stoves.
The way you dry wood to burn in your fisher may work fine but modern stoves need drier wood. If you don't want to test the moisture some information on the species of wood you burn and how long it's split and stacked (not in rounds) prior to burning could help confirm its not wood.
All the stoves in your original post are plenty fine but may not be any easier to run than what you have right now if the wood isn't really dry
drolet HT-3000
Drolet escape 1800
Any helpful inputs?
What are your current modern stoves that aren't working for you? We know stoves and we can say if the new drolet proposals would be any better.
Drolets are good stoves at a good price point and not finicky. They are modern noncat stoves though which means that they can't be burned low and slow like your old fisher. The "range" of available outputs will be much smaller and hotter.
Weve used wood to heat over 30 years, so I hope I have a little bit of understanding of the basics of whether or not wood is seasoned.
My experience with stoves is limited to older wood stoves. Thus im asking for information about good quality budget newer stoves that are supposed to be more efficient.
The wood was cut and split and stacked and top covered and seasoned two years.
Thank you. This is very useful. How is the reported burn times of 10 hours achieved without the low slow burns?
This is the information we wanted my man. 2 years sounds really good the reason we press is because most people don't do what you do and try to burn wet wood. You may have some operational issues to work out but you should be fine with a drolet they seem to put out a lot of heat when operated correctly
Of note, once you get a fire going in these newer stoves turning the air down is what actually gets the entire system hot not running It Wide Open
The chimneys are lined with stainless steel and that is insulated and they are about 22 feet of chimney.
Unstamped so not certain of manufacturers
Are the stoves in the same building?
If not, is the place with the newer ones rather airtight? Or with exhaust fans?
Are the newer stoves in a basement? Those can have lower pressure resulting in poor performance.
Does smoke roll out sometimes when you open the door?
Can there be ash build up in the newer stoves (on baffles or so)? Or could the air inlet be obstructed?
If your wood is not wet (and I agree it seems to look okay there), your chimney is reasonable (in height) and properly lined, and you have trouble keeping them going, air flow is not what it should be.
Another possibility is that the flues leak. E.g. an improperly sealed clean out door that sucks in air, competing with the draft your stove needs.
Just some questions to see if we can find out what the problem is with the existing ones as that would save $$ over getting new ones.
Drolet are a solid brand tho.
The question is why can’t that stove burn for 30 hours at a 3x lower and slower rate.
