Old Stove: 1/2 inch thick semi-air tight steel smoke dragon. Crank it full of wood, let it rip (out the heat and through the wood). Overfire? Hah! It laughed at high temperatures. The stove was easy.
New Stove: Lopi Endeavor and if I build any kind of normal fire (and the box is small 2.2 to begin with) and walk away for 15 minutes I come back w/ stove temps of 900 (plus, perhaps -- that's all the higher my thermometer goes). Flue temps are maybe 400. Then I have to shut it way back. If I filled this thing with splits and closed all the dampers I'm afraid it would melt.
Am I right in assuming these new secondary burn stoves are finicky and delicate and must be monitored like a toddler? My thermometer is right smack dab on the low step of the top middle of the stove. There is only one plate of steel there between the thermometer and the flue/secondary burn.
And it seems like there is no happy medium. If I have a good fire going w/ lots of secondary burn, the stove temp is way too high. If I damp it down to a "safe" temp, the secondary burn disappears. You mean this stove is too wimpy to make a secondary burn?
Incidently? The new flue is not sealed -- I tested w/ a lighter and the flame really gets sucked into the joints on the flue. Is that related?
I want an efficient stove, but I've got other things to do besides stand there and mointor the temp. Hmmmmmmm.
