Are gaps in the chimney flue really a big deal?
Ok. So, your mortar is compromised. Creosote is getting into the cracks. How do you get into the cracks to remove it? It’ll continue to seep into the chimney itself. On some older houses, you can see it seeping through the outside of the chimney. If it were to ignite and catch on the outside, there is nothing stopping it from igniting your house. A liner will stop this.
Here’s a pic off Reddit. I never thought to take pics when I saw it. I’ve seen it much worse though.
[Hearth.com] Are gaps in the chimney flue really a big deal?
Everybody is talking about installing a liner but what's wrong with older flues? How did you find the fact that creosote can go through the cracks?
How could it not? Creosote is condensed smoke. The smoke gets past the gaps and condenses.
How it this hard to imagine happening?
There is more than 50 inch of pipes connected to the stove before the smoke enters in the flue and then the flue is 20ft height from the connection to the top. I guess due to the long commute the temperature has time to decrease.
I also don't do huge and super hot fires. Only when I start it or maybe once a day
We can only advise you. Multiple people have told you that it is a huge safety hazard for you, your family and your house operating that flue in its current condition. Common sense should be common in this situation. If you choose to ignore it and something happens that’s on you 🤷🏻‍♂️
Reactions: kborndale
I bet that is correct. Startups are probably cooler too. Over years I bet this could cause the buildup behind the liner.
The thermal mass of the masonry keeps it from warming up quickly too.
When it comes down to it, we aren’t trying to sell you anything.
I encourage you to look into insulated liners.
