E
elkimmeg
Guest
Recently two of the worst creosote picture posted, were taken looking down masonry chimney block chimneys
Forum member Struggles live in constant fear of chimney fire danger till he lined his. I have been pondering why this is occurring in the chimney block setups with 8/8 flues in exposed chimneys?
A nominal brick measures 3, 5/8” Chimney block 3,1/8”
Is it that ½” reduced masonry thickness? Does that reduction promote more cooling within the chimney? Are these chimneys code compliant? Code calls for 4” masonry, which in reality 3,5/8”. There are no code exceptions for reducing this requirement to 3,1/8”
Another factor here might be that chimney block chimneys having more than one flue seen to work better? The furnace and or hot water heater are connected to the adjacent flue and do provide residual heat within the chimney. That may aid in both the wood stove draft and the burner’s draft. It seems the stand-alone exterior chimney is the most effected by creosote development.
Next factor: As wood stoves become more efficient, their draft requirements become more critical. Could it be that they are producing less heat in the draft cycle and more to the living space? They are not producing enough heat in the chimney, to draft correctly? Evidence of this, is the increased post complaining about poor performances in inserts installed in exposed exterior chimneys. Even code recognized this, when they amended the cross-sectional codes to reduce the area requirements of exterior locations.
At some point the wood used has to be questioned. We all know mister woodman sells seasoned wood, that is not ready for prime time. At some point the user practices have to be examined. In the effort to obtain longer burn times, are they dampering down too soon? Are they using wetter that dry wood? Have they choked down the air supply too soon with less than dry wood?
